My '82 GP's dash has some of the lights flickering in the area where the turn signal lights, brake light, and seal belt light cluster is located. Have had all of the light bulbs replaced in the dash years ago. Am wondering if the bulb sockets are the culprit. If so, I do have some sockets from a few dash gauge clusters I could use or would it be better to buy new ones from GM (that's if they're still available)? I used to work for a Chrysler/Plymouth dealer in the '80's and Chrysler used to have problems w/ the same kind of bulb sockets (they always ended up w/ broken tabs etc.).
Am I correct in that you have to disconnect the speedometer cable from the cruise control servo and then the gear shift lever cable (column shift) to take the speedometer/clock cluster out to replace the sockets? Am kind of afraid to mess w/ disconnecting the gear shift cable as it's so thin I don't want to end up breaking it! It there a trick to getting it lose etc.?
Thanks.
Thanks.
