Dash wire
SSmooth84
112
Sandiego,California's
Can someone tell me were the pink wire with the black connector plugs into I took my dash out and can't remember were it goes into or if it just hangs there ?
L92 OLDS
2,872
3,050
West Michigan
Pink wires are hot with ignition on. Yours could go to the ignition switch or maybe the rear window defrost switch?
oldsofb
1,368
3,962
Maryland
AT 14;15 of vid is the pink wire for power windows.
That is not the same wire from your pic. I think that one may hang loose. It could be for cars equipped with power sun roof, not sure. I don't remember unhooking that one on mine. (it's been a minute though 😁 )
Hutch
oldsofb
1,368
3,962
Maryland
Found it
That wire is for the Sunroof switch if equipped. I check continuity and it runs through a harness across the under dash to the passenger power window wiring connector.
No power sunroof and it just hangs there.
Hutch
