deal of the century ...factory G body swaybar
Jim Rockford
308
523
Shelby,N.C.
happened to totally run across a 1984 cutlass calais in the junkyard today, and it was pretty slim pickings but It did have the sway bars and steering box, but I snagged the rear bar today..20 bucks. Didn't get the front because I think My pontiac has the 1 1/8th inch bar on it plus I have a B4C front sway bar off my 92 camaro . someone had tried to remove the steering box top, and it had been sitting partially opened but I may go back and get it asa rebuildable core.
Reactions: 4 users
carnutjw
621
1,465
I know the factory rear bars are poopooed sometimes because they're not as effective as a chassis mounted bar, but if you drive a G-body without one and then with one, there is a difference in the butt wiggle. Good find.
Reactions: 5 users
Jim Rockford
308
523
Shelby,N.C.
Well for the price something is better than nothing, This isn't a pro touring car and Im not looking to compete with it in any autocross events, so I couldn't complain, G bodies in the junkyards around here are few and far between and finding a rear sway bar is even rarer. Hell my buddy even managed to find a manual steering box from a 84 s10 for his S10 v8 swap . guy on fleabay right now has a used rear sway bar for 189 bucks ..lol I'd rather spend 20 .
Cuse99
251
126
Pardon me for asking but what are those tabs on each side? Where the bolts go through? I bought a sway bar and I'm about to mount it but I don't see those tabs on my car.
Drkuhar
512
912
Girard, IL
Those are the spacers that go inside the lower control arms so the dont crush when tightening the bolts and stiffen them up. Ive seen people use pieces of pipe to do the same thing
Cuse99
251
126
But the spacers aren't needed right? My UMI sway bar came without them, no instructions to use them and I don't see these for sale anywere. I'm planning to mount my sway bar today. Hoping my day is not spoiled.
oldsmobile joe
2,067
3,053
mpls
565bbchevy
9,614
12,683
Michigan
You will need either the factory spacer or make your own if you are using factory non boxed lower control arms.
69hurstolds
8,195
17,596
Some kind of spacer needs to be used if using open lower control arms. Regardless if your sway bar comes with them or not. Otherwise you will crunch them.
