Please look it up for me and tell me which one is the correct one. The axle bearing they list 2 different sizes. I assume one is for the 7.5 and the other is for the 8.5 but it doesn't tell me what one is whatCan't you just look it up on rockauto?
2 - TIMKEN 5707 (axle bearing)
2 - TIMKEN 8660S (axle seal)
2 - TIMKEN LM501314 (carrier race)
2 - TIMKEN LM501349 (carrier bearing)
1 - TIMKEN M88048 (outer pinion bearing)
1 - TIMKEN M88010 (outer pinion race)
1 - TIMKEN M802048 (inner pinion bearing)
1 - TIMKEN M802011 (inner pinion race)
1 - TIMKEN 2043 (pinion seal)
sometimes you have to take it apart to know what you haveAny one know the part #'s for all the bearings and seals for an 8.5 rear. Carrier, pinion, axle. Its an 8.5 out of a 86 olds 442. 373. Any help would be appreciated
