Differential fluid capacity???'s
dickeymoore
698
Atlanta,Georgia
I just had a Grand National 8.5 rearend rebuilt and I poured 2 quarts of Lucas differential fluid in it is this enough fluid, it also has a aftermarket cover girdle on it?Thanks
64nailhead
Goat Herder
3,799
Upstate NY
No
64nailhead
Goat Herder
3,799
Upstate NY
3qts will be within a 1/4 qt depending on your cover/girdle.
melloelky
3,347
mass
if it's out of the car aim the yoke in roughly the same direction that it would be when installed and fill it untill it comes it like airboat said.when it stops coming out on it's own,it's full.
oldsmobile joe
1,857
mpls
its easier to fill when not in the car. a 7.5" axle takes 3.5 pints, (yes i know you have an 8.5) and a B body axle takes 4.25 pints. sorry, using a 78 olds manual for specs.
because you have an 8.5 and an aftermarket cover, i would put 3 quarts in it while its out and then drain out any excess once its in the car. jmo
