dip stick tube stuck
FirstClass 383
337
33
402
I got a 5.3 and the dipstick was busted off and i can for the life of me get that sucker out, the motor is on a stand not in car. ck on utube and they say pull and wiggle Nope it wont move at all, ive sprayed w-d on it most of the week cause out side of the block is RUSTY, has any one ever had this dilemma and if so how did you solve this b*tch of a problem
NickC
38
21
8
Idk for sure about the 5.3 I would pull the oil pan off and see about pushing it out from the bottom
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
It's pull and twist wiggling is what broke it.
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
See if you can tap it down into the oil pan then use a retrieval magnet to fish it out of the drain hole.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I'm confused, you spent a week spraying it with W-D while the engine is on a stand. Why haven't you removed the pan to push out with a drift punch
FirstClass 383
337
33
402
the oil pan is off, the tube was rusted as all hell. with some patience and a 5/16 lag screw a hammer and pair of vice grips i finaly came out
pans been off just rusty as hell
FirstClass 383
337
33
402
with a bit of patience, a 5/16 lag screw, a hammer, and some tapping, it finally came out, thanks for all the suggestions
