Just rebuild your stocker. I'd cost about the same if not a bit less. Curve kit, new module, cap, rotor, coil (if yours is bad), carbon button, and the little felt/rubber washer and you're good to go. Of course you could always go further with adjustable vacuum advance, new gear (just use a finish nail to knock out the roll pin, install new gear and tap pin back in GENTLY) if your gear is bad. But of course if you don't have a Dizzy, just either buy a used one off ebay or go junkyard hunting. Anything off SB or BB olds should work. Don't use one off a computer controlled vehicle. It won't work.
