Alright so I'm trying to decide on my 80's Caprice, on whether or not I should keep using the spark system that the ECM controls or simply go with a HEI with vacuum advance.
Basically, I want to keep my E4ME carburetor for right now, and save a bit of money. But I'm not sure what extent the computer is needed for this vehicle. I believe it has an external coil too, so does that mean I am using points? A little worried.
If I replace the dist and go with the current setup, I would use one that TBI setups have without the advance correct? Or should I just unplug the ECM fuse, get one that's vacuum operated and run it to one of the ports on the carb?
Thanks guys lol.
Thanks guys lol.
