Good Morning Guys; Since my education was auto engines & did work in an engine shop years ago, I'll toss in my $.02 cents. Polishing a crank is used to describe taking near nothing (.00001") off to as much as a half thou (.0005"). And even dedicated equipment can add eggggg (run out). So be very careful if you decide to do it yourself. Make some V blocks from a 2 x 6 or what ever. And I wouldn't use anything courser than 900 grit at home. Even the shop equipment can add egg polishing, operator plays a major roll, at least on older equipment that I'm familiar with. If the 900 grit doesn't clean it up & use a new strip on every journal consider taking it to a shop. And if ya got steady hands consider chamfering the oil holes before ya have it polished. And when ya get it back (done), CLEAN, CLean, Clean it. Get some small brushes & run them through the oil holes more than once. Soap & warm water, lots of it, rinse & spray while (water) wet with oil including oil holes displacing the water. Make sure that ALL the water is off before ya Bag it until time for use. Plastic gage at assembly, know your clearances. Good luck, Ole' Bob
