Do 4 door gbody hinges fit 2 doors
86MCSS86
47
8
Just wanted to know if the hinges interchange from a 4 door gbody to a 2 door. Do the back door hinges from a 4 door fit a 2 door?
gmparts
183
103
2 door and 4 door hinges are not interchangeable. 4 door rear hinges are 4 door and wagon only
81Regal
1,557
485
83
Terril Iowa
The front door hinges from a 4 door/wagon will fit a 2 door, not the rear hinges.
Ribbedroof
4,892
6,944
Wellston, OK
If you're asking because they're worn, replace the pins and bushings in them.
Believe it or not, I've seen a lot of sloppy wagon/sedan hinges, despite the lighter doors.
86MCSS86
47
8
I see so front 4 door hinges will work. The reason I ask is because mine are worn and look like a rebuild might not work. The little wheel is out off alignment and the door clunks when you close it. Would my hinge still be rebuildable with that issue?
