I've been trying to chase down a drive line vibration issue on my '83 El Camino.
Feel it at high speed.
Comes in at 60 and is the worst at 80 and then smooths out faster than that.
New transmission yoke, new balanced driveshaft with new u-joints.
Rear is a GM 7.5 with factory 3.42 gears (out of a Camaro) and an Auburn posi.
The pinion yoke is the one that came with the El Camino from the factory. It was a 2.41 open the way it came.
U-joint angles are good. Rear of transmission is down 1.6 degrees and pinion yoke is up 1.6 degrees. Driveshaft angle 3.9 degrees which results in a 2.3 degree u-joint working angle.
Did this procedure this morning.
What do y'all think?
Dial indicator in center of u-joint cap and calibrated to zero:
Turned 90 degrees. .018 difference:
Turned another 90 degrees. Now opposite to the calibrated cap. .004 difference:
And another 90 degrees to the last spot. .009 difference to the calibrated cap and .009 less than the opposite cap:
