Do You Even Catch Can, Bro?
motorheadmike
motorheadmike
3,076
5,409
Ottawa, Ontario Canada
#1
Did an oil change on my TBSS today and part of that procedure is emptying and cleaning out the catch can. Keep in mind this is just a modified eBay unit (internal straw and scouring pads). The oil was last changed on 26 Nov 17 as the vehicle didn't get a lot of use in the Spring/Summer/Fall thanks to the wagon, and many of its trips are short runs into town.
And this is what I found:
20190112_174316-jpg.103650
It looks like my coffee.
Poured a solid 2 ounces out of frothy smegma, and then rinsed it out with brake cleaner. There was none of this under the fill cap.
The point is if you don't put one on your engine you risk missing clues like this, and also allow all that crap to get pulled into the intake.
fleming442
fleming442
4,598
4,624
More than just condensation? Think it's a blown head gasket?
I had a similar experience today on a friend's '10 f150, 4.6: a ton of schmegma on the inside if the oil fill and "PCV" line. I attributed it to condensation build up because of his extremely short commute. The truck never gets warmed up enough to burn off the water mist....
airboatgreg
airboatgreg
1,289
1,208
Did all of the oil look like that?
Can you look in the rocker cover when you remove the oil fill cap?
FluoFerret
FluoFerret
Apr 2, 2018
57
44
Luxembourg
#4
I installed a catchcan too from Moroso. Nothing fancy, but gets the work done. Up til now, after 1 season, I had a spoon of oil in there. Looks like the engine runs pretty okay here ^^
TURNA
TURNA
6,016
7,423
Socialist NY
#5
Do you run a pcv valve?
motorheadmike
motorheadmike
3,076
5,409
#6
Definitely not a blown HG or a head lifting under boost. The rest of the oil was normal and no coolant is missing.
motorheadmike
motorheadmike
3,076
5,409
#7
No issues with the oil, and pulling the valve covers would take hours.
motorheadmike
motorheadmike
3,076
5,409
#8
Yes, stock and some check valves for redirecting the vacuum source to the blower inlet to create crank-case vacuum under boost.
lilbowtie
lilbowtie
2,312
2,063
Canton Mi
#9
If your not going to investigate your clues why have it. That's not right!
motorheadmike
motorheadmike
3,076
5,409
#10
Which I did and everything is okay - root cause being condensation build up from short drives in the Winter.
