Hey everyone
I just finished a complete drivetrain swap in Project Olds Cool, which included retiring the worn out old 305, and replacing it with a built 350 Chevy.
The car was originally an AC car, but it never worked since I got it. Because we really only have maybe a dozen times a year where we really need AC, the pump, lines, evaporator, condenser etc was removed to tidy things up.
I replaced the heater core along with all the fittings and hoses but kept the original AC HVAC box. The heater hoses are routed the old school way directly to the heater core and back with nothing inbetween.
The HVAC fan is only blowing regular air, no heat when it's on the heat setting. I'm about 80% sure the blend doors are working and in the correct positions as I didn't change any of that during the swap. Which brings me to my question:
Does anybody know if there needs to be some sort of flow restrictor inline in one of the heater hoses or heater hose fittings in non-AC 305 or 350 applications?
I know some engines like my 455 had them built in to the heater hose fittings to restrict and slow coolant flow through the heater core.
The fitting in the top of the water pump is the only stock fitting I was able to use. I've done a Vortec head swap and the Vortec intake manifold only has provisions for 3/8" thread fittings, so reusing the stockers was out.
The water pump is new, and both heater hoses get hot, so there's obviously flow through the heater core.
If the answer is no, there's no flow restriction needed, the next question obviously becomes "why then, is it not blowing warm air"?
Here's a couple of photos for reference if needed.
Any insight or information provided would be greatly appreciated.
Thanks in advance.
Donovan
Thanks in advance.
Donovan
