Does anybody use a zddp oil or additive in their car?
fly_25
136
67
I have been trying to find the best oil for my 3.8 v6, should I be using an additive for zddp? is it really necessary?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
  • Winner
Reactions: 5 users
blk7gxn
1,390
1,886
Years ago, car manufactures wanted to get 200K on catalyst converters, HOWEVEVR this was not achievable with zinc in the engine oils, (ZINC CLOGS CONVERTERS OVER TIME) that's why most oils use other additives other than zinc. If you purchase (for instance) Mobil 1 High mileage, it contains zinc, so do other high end synthetic oils. I use the ZDDP additive in all my Turbo 3.8 V6's, its truly worth the coin for the added protection. I use the High mileage Mobil 1 AND the zinc additive, best of both worlds!
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
  • Informative
Reactions: 4 users
gnvair
1,102
1,304
I belong to another car group that includes an oil engineer that explained that adding ZDDP additives can cause more harm than good as too much is just as bad as too little. I accept his advice over others and that is to buy an oil with a good additive package such as Rotella, Brad Penn, Valvoline VR or other racing oils.
Note that you only need the additives on engines with flat tappet camshafts. Roller cams do not need the additives.
I run Brad Penn in my one vehicle that has a flat tappet camshaft.
