I recently got a used lighted rear view mirror with Donnelly 263.0 written on the back. After doing some research its a pretty common mirror but I cant find anyone that swapped it into a gbody. It has 4 wires - a black(ground), pink/black(switched power), orange(constant power), and white(ground with open door) from what I found online. I have the orange wire spliced to the orange dome light wire and the white on the white dome light wire. The ground is on a steel roof brace and the switched power to the gauge light fuse. Is this right? I assume this is right but I dont have a wiring diagram for the monte so its kind of just spitballing. The lights do not work and neither does the factory dome light. Even with the interior lights turned on with the headlight switch there's nothing. What would be the first thing to look for? All fuses are good, gauge lights work but no dome light or mirror lights. Anybody use this mirror or have any ideas?
