Hello all G-Body enthusiasts! I pulled driver side front door off my '85 Cutlass. Needs to do something to hinges, they're quite loose. Which are proper pin and bushing kit? I searched at Rockauto these: Hinge pin&bushing ?
Oh, there it is, thank You!1986 OLDSMOBILE CUTLASS SUPREME 5.0L 307cid V8 Door Hinge Pin & Bushing Kit | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.www.rockauto.com
Yes, I think upper is worse and I have to weld and drill it, Thanks!Make sure the holes for the bushings aren’t enlarged/longated. The repair kit won’t do any good if they are. I’ve had to weld the holes up and redrill in the past. On my current Elco project, I used the upper hinge from a Cutlass Cruiser. Works great
For some stupid reason it didn't show under 85 on rock auto, but went to 86 on a Google search.Oh, there it is, thank You!
