1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
DOOR HINGE REBUILD?
Discussion in 'General Discussion' started by vene09, Dec 15, 2009.
Thread Status:
  1. vene09
    vene09 Not-quite-so-new-guy
    Dec 4, 2009
    9
    IDAHO
    has anyone ever fix a door hinge on a cutlass, buick or monte carlo? i need to rebouild my driver side door, its kinda out off place!!! i was wondering if its an easy do it your self, or if you need special tools? or should i just pay do get it fix? my car is a 1986 Cutlass Supreme!!!
  2. billyjack
    billyjack Master Mechanic
    Mar 27, 2009
    448
    16
    Western PA
    Not really a difficult job, just take your time. Patience is the most important tool. I prefer to support the door, and remove one hinge at a time. With the upper hinge on the bench, grind down the staking on the hinge pin, remove the pin, and replace the bushings. Install the hinge and repeat process for the lower hinge if necessary. The only special tool that would help speed up the job is an "s"-shaped or "c"-shaped wrench for the hinge bolts, but it's not absolutely necessary. You'll also need a Torx bit to adjust the striker. I seem to remember a tutorial post in the past. It may be worth your time to do a search for it.
    Bill
  3. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    7,975
    1,481
    Gainesville, Fl
    Another useful tool in doing this procedure would be a spring compressor to remove and work on the hinges equipped with springs. http://www.hotrodautosupply.com/eshop/i ... oductId=12
    Any good body shop supply would also carry this tool. I bought mine from Eastwood.
    Jack
  4. 79loserbluebu
    79loserbluebu G-Body Guru
    May 9, 2009
    964
    12
    Illinois
    The door spring tool is a life saver
  5. cdg1984
    cdg1984 Royal Smart Person
    Oct 18, 2009
    1,009
    2
    38
    Evansville IN
    Its a lot easier to have someone help you then to do it by yourself and support the door. Just dont make the mistake I did and hammer the pin if it doesnt want to come out. I bent my hinge to hell and had a tough time getting it bent back in place. Also, for me it was easier to unbolt the hinge from the body and take the whole door off.
  6. 85GPLef41
    85GPLef41 Royal Smart Person
    Nov 14, 2008
    2,178
    46
    48
    Colorado
    I bought mine from a 4 door cutlass seeing as mine were to shot to repair with the bushings and pins. I supported the door with a floor jack and secured it so it wouldn't fall. I bought the tool and it helped out quite a bit it cost me around $15.00. I brought them to work and used a air hammer and a cutoff tool so it went alot smoother. But it could be done with a hammer and a chisel.
  7. Caballero
    Caballero Apprentice
    Oct 12, 2009
    58
    gbodies do tend to have problems with the doors hanging don't they. I know mine could probably be tightened up some.
  8. mickiez40oz@yahoo.com
    mickiez40oz@yahoo.com Greasemonkey
    Jan 9, 2009
    101
    Wisconsin
    There are some damn good replacement pins out there now, ones with hardened tool steel shafts & with a grease zerk at one end. Hot Rod magazine did an install of some a few years ago, if I remember correctly they did them on a 3rd gen Camaro(which more than likely have the same pins). I just spent a few minutes Google'n for them, but didn't find exactly what I was looking for...But I know there out there.
    For an EXAMPLE, here is the closest thing I could find right now without spending all night:
    http://www.mustangsteve.com/hinge.html
    [​IMG]
  9. vene09
    Dec 4, 2009
    9
    IDAHO
    whats the tool Call'd?
  10. username
    username Master Mechanic
    Jul 21, 2009
    350
    Tennessee
    I just rebuilt all 4 of mine for around 25 dollars last month.I got the replacement pins from the HELP section of Autozone.They were not the hardest of materials but very comparable to what I removed,and if they lasted for 20+ years running dry I figure these pins will suffice.The only one I had to fudge a little was the roller as I couldnt locate a replacement,but the roller for a 88-9? c/k pickup is the same dimensons save being about 2" longer in oal.I just drilled the hinge for the longer pin length and cut off the excess.I had my doors removed at the time for paint prep so this made hinge refurb easy although it can be done with the doors on the car.This is a very straight forward process of remove and replace,you will need a die-grinder or something similar to remove the staked end of the pin this allows the old pin to come out with a minimum of force.Your replacement pins should have 2 sets of bushings original and oversized,wear will dictate which one to use.Another possiblity is get a set from the junkyard and rebuild them on bench then R/R hinge as an assy.
Loading...
Thread Status:
Share This Page
