Door is sagging pretty bad. Gradually got worse since I owned it. It's to the point where I think I'm gonna break the window when I slam it shut. Will a kit from an auto part store be what I need to fix this? 173401 and 173354 is the top hinge....
Oh. I wasn't sure if something was broken. Top hinge looks like a pc is bent or something.Can't really see the pin or bushing on the upper, but the lower looks like pins/bushings should get it. The roller is a little harder to find sometimes.
I use Astro van pins and bushings, the Astro pieces have a retainer on them that takes the place of staking the pins to prevent the pin from coming out.
Main thing to look for is whether or not the pin has worn through the bushing completely and eaten into the hinge base metal.
I knew it looked bad but wasn't sure if a "kit" would be good enough....passenger side shuts pretty nice. Is it better to bring to mechanic or do myself? I don't have anyone to help me....It looks like a pin and bushing kit is not going to fix your hinge. Usually it's the driver's door that shows the most wear and I would order a complete upper and lower hinge assy. The passenger side Could be saved with just pins and bushings.
ps: the doors are heavy
Ed, I don't agree. As long as the hole isn't majorly oblonged, they'll repair.
