Has anyone had their door go clunk-clunk-clunk when opening? Both of my doors are doing it. I just replaced the upper hinge on the drivers door with a nice tight one off of a 4-door Malibu (which I found out has a smaller spring) thinking it would cure all issues the old (hogged-out hinge pin hole) one had. As soon as the spring was reinstalled and tension was put back on the bearing during installation, it started to squeak and clunk just as, if not worse than, the worn out original had.
Are there any replacement bearings available out there? I have seen the Dorman/"Help!" ones at Auto Zone, but they look different (I think they are for GM trucks). If not, are they rebuildable somehow? I soaked the one on the current hinge in 5W-30 synthetic motor oil for a week before I installed it, but it takes about a whole can of WD-40 to make it somewhat tolerable now. Any ideas?
