Door Speakers
MechMan
MechMan
198
36
Long Island NY
#1
I was looking on Dixie Restoration and i saw they offered door panels that have a speaker location. Has anyone added or reolacted the front speakers to the door? How hard was it and would you suggest putting tweeters in place of the dash speaker?
fleming442
fleming442
5,860
6,609
Former stereo installer here- I made some kickpanels out of 3/4" MDF and hung the tweeters under the dash corners in mine. It's a concept called psychoacoustics where your brain gets fooled into thinking the soundstage is directly in front of you by equalizing the pathlengths to each ear, as best as possible within the confines of a vehicle cabin.
Now with all the technical mumbo-jumbo out of the way, let's talk G-body physical limitations. First, the door panels don't have much usable depth in the prime areas where you would normally mount speakers, THEN you have that goofy ledge extending forward from the armrest limiting speaker circumference. SO, that leaves you a space to mount puny 4" (maybe 5 1/4") speakers by cutting holes in the panel and door metal to do it conventionally. Otherwise, you need to build a custom panel either integrated into or replacing the lower section to build it out enough for depth and circumference of a decent driver. I'll be doing a set of 8s in all 4 doors of the $200 Cutlass for my buddy in the next couple of months. I'll be sure to chronicle the event here.
Pics of my kickpanels: https://gbodyforum.com/threads/operation-lipstick-on-a-pig.64137/page-55
MechMan
MechMan
198
36
Long Island NY
#3
fleming442
fleming442
5,860
6,609
Sorry, I did kind of glaze over the original question, but they do replace the lower panel as I suggested. They would work, but ABS is extremely subject to making noise (buzzing, rattles, etc.) when a speaker is involved. If you go that route, consider them cosmetic only, and reinforce the speaker mounting surface as much as possible.
MechMan
MechMan
198
36
Long Island NY
#5
You know more than I on this stuff. I welcome any insight into this.
J
Jweb
Oct 20, 2018
74
97
Salem, OR
#6
We just installed a set of those door panels that hold 2 speakers per door. They fit good and installed easily. I can't say how the sound is since the new owner of the car will be installing the stereo. I would say if your door panels are in bad shape these would be a good option, if your door panels are good build some kick panels like fleming442 suggested.
This is in a Chevy truck but is a helpful write up on building kick panels Sonic Nirvana
Dixie Restoration Depot
GBodyForum Sponsor
Oct 24, 2016
88
246
33
Manchester, CT
#7
We may be a bit biased here but after installing them in the shop car and thoroughly testing out the stereo, the only time we ever see an issue is when people try to put a pair of 6.5-inch speakers on and they have a very large magnet. Even then it tends to be a not enough room situation more than anything. If you do plan on using a lot of bass we recommend a dynamat type insulation on the door to help with the vibration. As always if you have any questions feel free to give us a call.
565bbchevy
565bbchevy
6,129
5,165
Michigan
#8
On both my Monte and Regal since they power windows I installed 6.5" door speakers where the window switch would be and moved the switch to the lower door panel.
On my Monte I installed a component set up and put the tweeters where the 3.5' speakers were and the Regal I installed new 3.5" and have a 2 way door speaker.
I also made the upper door panels to make a dedicated spot for the speakers.
img_0897-jpg.104093
20170716_205401_resized-jpg.104094
CaliWagon83
CaliWagon83
1,843
1,925
Orange County, CA
#9
Has anyone done oval speakers hidden behind the carpet strip along the bottom of the door? I'd like to add a few more speakers, but keep kind of a stealth appearance.
fleming442
fleming442
5,860
6,609
It can be done fairly easily. It wouldn't be on my list, though.
Thread starter Similar threads Forum Replies Date
H Interior 1
B Interior 9
T Interior 13
Martin S. Interior 12
jdwheat1 Interior 11
Similar threads
