I think you spent more on repairing the old AC compressor (tools), than just replacing it. I'm thankful I bought a really nice compressor for $35, and I had the AC delete pulley from another project. So that PIA can go away for most others who decide to convert. The radiator hose that supposedly works is AC Delco 26003X, or that Mopar one that other Member had used. (I haven't bought either one yet, to know for sure) . I think you should get your daughter involved here... insert your ratchet into the tensioner, and have her hold it in the middle of it's range while you measure the length with some rope/wire. This should get you close. IIRC alot of the aftermarket belts have their length incorporated into it's part # ( ex. 7819 = 78" belt ) so if you have to return it, simply ask for the next part #.. 7919, 8019, 8119 etc. I originally wanted to run a mechanical fuel pump for simplicity, and reliability, but about a month ago when I started seriously gathering parts for this conversion, I decided to run an electrical fuel pump installed with a relay. Thanks for posting your progress. Looking forward to the final result... which I hope is Satisfaction!
BTW, I'm sending my Mustang pulley to Larry for modification.
