Dr Olds Burnout Machine
1bad79
1,023
890
Allendale mi
I pretty sure the upper hose is from a 03 dodge Dakota so olds 307/403 probably has that part😃
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
That is awesome nicely done!!!
What did you need besides the SBC aluminum brackets
Oct 14, 2008
8,819
7,766
Melville,Saskatchewan
Interesting on the upper hose, I will pick up one. I assume for the 4.7 V8? Actually my Dakota has the rad cap in the upper hose, so different. Is that the Ford crank pulley? As I have said, you need the Olds 4.3 V6 diesel water pump for the sbc set up to work. I am buying Larry's setup and I am stealing the idea for the crank pulley alignment from the other guy, what comes around, goes around.
Tuffregal83
639
1,150
Lockport, Il
I love that set up I want it
No more belt squeal
Oct 14, 2008
8,819
7,766
No more belt squeal
Yes, Olds factory V belt set up is complicated and the 3 different water pumps make it more fun.
1bad79
1,023
890
Allendale mi
I got the adapters from Larry 302 crank pulley I welded it and turned it to the correct size and the rest was 4.3 blazer 95 and earlier so I could retain the ac compressor the compressor manifold hose is 92 camero the alternator is 95 and newer gm (cs130d) the p/s pump is Astro van the hydro boost, lines and box are all 81 and up gbody so stock lines fit from the pump to the booster to the box all stock gm parts they did the r&d I just put it all together
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Ok not for nothing
but who the **** is Larry??
MrSony
6,826
6,731
Des Moines, Iowa
  • Happy
