Draining master cylinder
mc1984ss
296
243
Draining master cylinder​
I had to pull the proportioning valve / combination valve out of a car. ( Everything was nicely painted) Needless to say this was a messy job. I know I will never get it back in without making a huge mess and brake fluid running all over the place. If I allow the master cylinder to drain but don't press the pedal will I need to bench bleed it again? I think I did this years ago and since I didn't touch the pedal I was fine. Thanks in advance I appreciate it
airboatgreg
2,867
3,115
You will need to bleed again for sure but i would gravity bleed first. Probably will not need to bench bleed
malibudave
204
227
Houston, TX
If the master cylinder is drained dry, you will most likely have to bench bleed it again since air may stay trapped inside the cylinder because of the angle of the firewall tilts the front of the master cylinder up.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you will need to bench bleed it....if you don't want to removed the master you can use this method...
