Drill and tap size for grease fittings?
C
clean8485
2,313
940
83
Ontario, Canada
#1
I'm upgrading the front sway bar on my Malibu, and going with greaseable bushings where it bolts to the front frame rails. I'm going to be drilling and tapping holes in the frame mounting brackets for the grease fittings (zerks). Does anyone know the drill bit size for the hole, and tap thread size for the grease fitting? Thanks in advance.
565bbchevy
565bbchevy
5,921
4,934
Michigan
#2
Are you talking about making something like this?
proxy.php?image=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2FkmoAAOSwfRdZIECm%2Fs-l1600.jpg&hash=df3968ad31a538e1f5ff2c98edba4c00
C
clean8485
2,313
940
83
Ontario, Canada
#3
Yes. That's what I'm doing.
565bbchevy
565bbchevy
5,921
4,934
Michigan
#4
The above style was designed with a dedicated raised up area for the grease fitting and it's threads, on a stock one wouldn't that leave you with very little metal to tap into and once you install the grease fitting wouldn't it be pushing against the bushing inside and possibly not have enough room to release the grease properly. Just my thoughts without seeing what you are working with.
Z
Zspoiler
Jun 3, 2018
85
54
#5
Judt check and see what the fitting size is on the grease able aftermarket bushings
C
clean8485
2,313
940
83
Ontario, Canada
#6
I've done this modification on my '84 Monte, and it worked well. I bought the bushings from a company called Top Down Solutions. I've lost the information on the drill and tap sizes that came with those bushings, and that's why I'm asking.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,191
9,405
Kitchener, Ontario
#7
I have drilled and installed the zerks. I don't recall what size drill I used but I didn't bother tapping the hole, the zerk made it own threads. If do tap just remember the threads on the zerk is tapered fo if you tap all the way through the hole the zerk will fall out
pontiacgp
pontiacgp
Mar 31, 2006
24,191
9,405
Kitchener, Ontario
#8
the engery bushing I have a hole drilled into them with no grove
bob64
bob64
686
608
Niagara Falls, Canada
#9
Grease nipples come in a wide range of sizes an depth of threads, so best to get them first. So that alone makes it hard to tell you what to drill an thread.
If it was me l would check the grease nipples with a caliper for size and drill a hole 1 size smaller an force thread it in. Buy short threaded nipples just enough to go threw the metal an not into the bushings.
I've done it a few times and it worked well, Just some thoughts
C
clean8485
2,313
940
83
Ontario, Canada
#10
Thanks to everyone for your help.
