Drive shaft length needed
Hi guys,
My 700R4 went on strike this weekend on the way home from Goodguys in Columbus. It is now a two speed, since third and fourth are nowhere to be found. Fortunately my original 200R4 freshly rebuilt by Extreme is waiting to be reinstalled. My question is, what is the original length of my driveshaft before I cut it for the 700 transplant? I want to know so I can get one made before the trans goes in. I need to know if you are giving overall length or center-to-center of the u-joint. Another question, should I go with aluminum or steel. I have one of each, but both are too short.
Thanks in advance,
David
Blake442 said:
Don't forget that the 442 and GN driveshafts are 1" shorter than other G-bodies because of the 8.5" rear.
Did the GN and GNX have aluminum driveshafts? I am leaning toward the aluminum if the cost isn't too much.
JBreu
2,168
20
38
Livonia, New York
JBreu said:
If you have the stock 7.5 rear then you would need 52 1/2" from center of U Joint to center of U Joint, and if you have the 8.5 then it's 51 1/2"!!! Here check this link out as well: http://www.montecarloss.com/community/u ... Post762415
Thanks JBreu, looks like my drive shaft has been too short all along. I think I had it cut to 49" c-c. I'll have to get a price on the aluminum vs. steel and make my decision.
Thanks again
I just ordered an aluminum driveshaft at 51 1/2 c-c. I am wondering now though, is the length correct for the sbc i my car. I forgot about that. Did the 307 set in a different location?
84cutlass383
387
36
Oklahoma City
how much for the aluminum driveshaft?
$306.00. I put it on hold, they have it cut but not welded.
Blake442
6,864
1,996
Minneapolis
SBC or SBO doesn't matter. The flange of the bellhousing will be in the same place.
As long as the trans is in the stock location, 51.5" is the length you need.
