Hypothetically: If you had a cracked head, needed to move a vehicle that otherwise ran well, and towing was not an option, could you drive a vehicle a short distance with a cracked head? The drive would be less than 100 miles. The crack is at the top of a straight six head, between two exhaust valves, not affecting compression in any cylinder. Coolant is leaking up out of the crack and into the valve cover area, draining down and mixing with crankcase oil. The crack is small, and the leak is small, taking a long time to ruin the oil. You could remove the radiator cap which would stop the coolant from building up pressure. You could remove the thermostat too which would help relieve pressure. And finally you could drop the coolant level down to below the crack. Theoretically that would keep the coolant from leaking up into the valve cover area since that is the highest point of the cooling system. Without saying just tow it, do you think this would work?
