Driver door is sagging
Mike Geepers
Mike Geepers
Feb 1, 2018
58
33
Cen-Cal
#1
Hello forum,
I have a 78 monte and the driver door is sagging. I think its sagging from the rolling pin on the door, but no auto parts store carries that type of pin. Does it even change out or do i just change the other 2 pins located farther back?
565bbchevy
565bbchevy
5,824
4,801
Michigan
#2
They sell bushing repair kits to fix your existing hinge and they also sell new replacements hinges.
565bbchevy
565bbchevy
5,824
4,801
Michigan
#5
They look something like that just verify application before buying, it is a pin and bushing kit, you drill out your enlarged worn out hole and install the bushings and then the new pin.
Mike Geepers
Mike Geepers
Feb 1, 2018
58
33
Cen-Cal
#6
What i am asking is, does that roller style pin ever get replaced? Cannot find a pin similar to that in my auto parts store, and that style was too big this application
Pic for reference
Mike Geepers
Mike Geepers
Feb 1, 2018
58
33
Cen-Cal
#8
That is the door stop. It isn't causing the door to sag. It may cause the door to groan or squeak, but not sag.
Blue circle is causing door to sag: View attachment 91870
Thank you for the clarification.
Tomorrows project so it seems....
D
Doug Chahoy
849
553
#9
Don't be surpised if that doesn't fix the problem. As old as that car is and as long as it's been sagging it probably won't. I replaced my hinges with ones from a lighter 4 door. One adjustment with the striker and all was fine.
UNGN
UNGN
2,595
1,971
Southlake, TX
#10
That is true, It will help a lot, but the door can still have some sag and the hinge is still old.
Goodmark makes new hinges for $35:
Upper Left Door Hinge
Thread starter Similar threads Forum Replies Date
T Interior 13
MechMan Interior 10
Martin S. Interior 12
jdwheat1 Interior 11
dickeymoore Interior 2
Similar threads
