Re: Driver side rear sags lower then the right about 2 inche
1972cutlass said:
I don't know why it sags I put new springs about 2 years ago moog was the brand I noticed it was a little off with my 14 inch tires but when I went to my 15x10 with 275/60/15 it sags big time I've checked the body bushings and suspension bushings and every thing looks good I'm Going to swap the spring across and see if it sags on the passengers if so ill just have to get a another set. Has anyone else had this problem? I also have air shocks it mostly lifted the passenger side so i let out the air.
I've had the same problem in my '87 since the day I bought it except that mine sags on the passenger site. Put new rear springs in and that didn't help any.
I have had a complete new rear suspension in the car with the same results and now, even after the complete frame-off restoration and a completely new/different rear suspension, guess what? It still sags. I've had the frame checked on a frame machine and it was spot on so that wasn't the issue. At this point, even though it's just a band aid, I may trim one of the rear springs a little shorter than the other just to see if I can get it to straighten out. Or create a spring spacer to do the same thing.
If you figure out what the problem is I'd like to know.
