driveshaft length with 700r4 stock rear end
bizzyboi
36
going to be using a 700r4 trans, any idea of how long does the drive shaft needs to be shortened? i don't have my engine and trans put in my car yet so i cant measure myself, but id like to see if i could use this aluminum drive shaft, anyone know what length it should be?
JBreu
2,168
20
38
Livonia, New York
49 1/2 " from center of U-Joint to center of U-Joint....You can get yours cut 3", so long is the car had the th350 with the 6" shaft:)
bizzyboi
36
i dont know what this driveshaft came out of was under a shed in the back yard, im going to measure it later and hopefully it will work. quick ? question what can i expect from to get from this ds other than just less weight?
GP4U2NV
194
-1
Cincinnati
The up grade is not needed unless huge power is being made or vehicle is being used as a track car (not 1/4) mile.
My stock with a 3 speed was 3 inches too long. I got mine cut and new joints and balanced for 150$ tax included
bizzyboi
36
the thing is that if it will work i can get it for free, so either way with an aluminum or steel drive shaft both would end up needing to be cut so i rather go with the lighter 1
dogsht
2,003
9
36
Dayton, OH
Three speeds are best left in the 70s. Good for a drag car or if money leaves out the better options.but almost as obsolete as wood spoke wheels on a good quartermile geared street car. Gas got expensive & so did labor & parts for rebuilds. I'd sell the 700 someone needs it. You would be best served with what the General put in their performance gbodys, the 200-4R. No cutting driveshafts etc to make it work plus better gearing, more efficient etc.
bizzyboi
36
my car didnt come with the transmission. i already have a 700 so thats what i have to use. reading up on them they dont seem to be that much different other than size
