Drop spindles
barry malibu
26
32
13
The Netherlands
I have been busy with the drop spindles only the weel-bearing does not fit over the shaft.
the axis of the drop spindle is larger
I added the pictures for the difference.
Does anyone have a solution?
the malibu is original a v6
melloelky
4,157
9,553
mass
the 78 had the different bearing size than the later model years,the dropped spindles might be cast'd for the more popular 79-87 size bearing.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
If I'm not mistaken, '78 spindles used different size bearings. I think it was a one year only deal. I'm sure the new drop spindles would be sized for '79+.
You might need to pick up '79+ bearings.
*Looks like you beat me to the punch, Chris.
barry malibu
26
32
13
The Netherlands
Okay, thank you
I did not know that there is a difference in 78 and 79.
Thanks
pagrunt
9,159
15,328
Elderton, Pa
The '78's also have a different rotors too cause of the bearings. You'll need the bearings ('79 up) and rotors ('79-'81 with inch studs) to make those drop spindles work.
Longroof79
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Yep, we forgot the corresponding brake rotors. Good catch.
barry malibu
26
32
13
The Netherlands
GetFileAttachment
A-body
that is new to me
Van:
airslamit - travis <[email protected]>
Verzonden: maandag 15 januari 2018 16:41
Aan: barry willemsen
Onderwerp: Re: Your order: 11837
Barry,
The problem is you 78 malibu is a A-body not a G-Body. These spindle only fit the G-body cars.
The mail I received
pagrunt
9,159
15,328
Elderton, Pa
GetFileAttachment
A-body
that is new to me
Van:
Barry,
The mail I received
A & G bodies for '78-'88 mid-size GM's are the same platform. The parts (spindles) do interchage/fit. That person in the email you recieved does not know of the GM changing od A toG in '82. As we have noted you'll need to just get the rotors & bearings for the '79-'81 Malibu's to make those spindels work. You could even use '82 & newer rotors (using the '79 & newer bearings as they are the same) but they'll have 12mm wheel studs compaired to the 7/16" studs your Malibu have. Go to http://www.rockauto.com/ and use their catalog listings to cross reference parts for your car. This fourm will be your best resource to help find & guide you to the parts you can use. I've had my Monte since '90 & found info I didn't know from this fourm.
barry malibu
26
32
13
The Netherlands
Can you please show me what I need at rockauto.com?
part numbers or photos?
my English is very bad, I do everything with Google Translator:mrgreen::mrgreen::mrgreen::mrgreen:
  • Winner
