Guys, a piece of advice from an old dude, I've been in the auto body and interior trim business since the 70's. Before dying vinyl, clean it with an alkali cleaner like Fantastik, let it dry, scuff it lightly with 600 sandpaper, blow or wipe it off, wipe down with lacquer thinner and spray as stated above with light coats then finish with a medium wet coat. Always use the clear that Dulpi color and SEM both sell, in whatever gloss you like, it will look and last 10x better. As for carpet and cloth, clean it with Fantastic and a brush, allow at least 24-48 hrs drying time, use very light coats with at least 10-15 minutes between coats, as mentioned use a brush to lightly separate the fibers about every 2-3 coats. Do not use any heavy coats on fabrics or carpet. It takes a bit longer, but patience is virtue this time. :wink:
