E-85
justdandy
21
5
78
I want to run 8-85in my elky. I run 93 oct now for knock supression 'cause of the engine build. My car is '84 base coupe el Camino, It had 305 w/ lock up converter when I bought it 10 or so years ago with 81,000 miles. I drove it to FL from Colorado.
Now has a hot 400SB, 700R4, posi, with fitech TBI. Fitec says I can run E-85 just have to up my cu.in 30%. What do we know about fuel lines? I've replace all my rubber with auto part store rubber line in the last 4 yrs. Do we know how to ID rubber line that is fit for E-85?
I want E-5 for cost and performance.
I'd be glad for any input. thanks
From what I remember you need to be able to flow almost 1.5 times the e-85 compared to gasoline. So that requires a modified carburetor to flow that much fuel, and a pump that can handle the capacity. Ethanol will eat standard rubber lines over time, so make sure they are compatible with ethanol.
Reactions: 86LK and Rktpwrd
he did say Fitec so that indicates fuel injection to me, no carb. IIRC, we had a thread on this a couple months ago about rubber hose. do a quick search for it, but yes, you will need special hose and you'll still need a return line if you don't already have one
ok I got it the e-85 hose spec is SAE 30R14. gotta get under and look at what I've got. thanks friends
f
