Early G body brake light switch (with cruise) function
81cutlass
4,639
13,542
Western MN
Anyone have an early (78-83?) G body brake light switch with cruise sitting around that knows the pin function before I order one?
I know the brake light prongs (closer to the threaded part) close circuit when the button is out (brake pedal pressed)
Does the cruise circuit prongs (closer to the back) close circuit when the button is pushed in (brakes not pressed)?
I need a switch that creates a closed circuit when the button on the end is pressed.
64nailhead
Goat Herder
Dec 1, 2014
5,660
12,062
Upstate NY
Edit - I should read the question more closely - cruise, not TCC lockup.
carry on and ignore me
81cutlass
4,639
13,542
Western MN
OK, from what I see I THINK the cruise side is normally closed and opens when the brakes are pressed. I'll order one up and make sure.
Thanks!
