ECU converter 200r4 lock up control
9,611
12,668
Will the ECU still work to control the lock up function for the converter if everything else like dist, carb, emmisions etc. are disconnected just leaving the plug in the trans with power and ground, I am assuming it needs inputs to know when to lock up.
Clone TIE Pilot
3,853
2,598
Galaxy far far away
No, the CCC system is an all or nothing system. You are better off leaving the CCC system intact.
19,992
I bought this
The Painless Wiring one is a POS
9,155
15,321
Square bodys with lock up trans use a vacuum switch on the engine tired into a stand alone harness that could work.
9,611
12,668
I bought this
I already have the B & M above and am in the process of installing that now.
So do you have this installed already and how do you like it?
Did you have to go into the valve body?
19,992
Its sitting in the back seat
Didnt look like you have to go into the valve body
9,611
12,668
I just finished the under car part of the install and the wiring through my firewall looks long enough that you could probably mount the unit in the back seat.
I guess it would give you the option to mount it in the glovebox or something.
DoubleV
2,154
406
83
Medina Ohio
What's so bad about the Painless kit?
19,992
I locks at 45mph and you just chug along.
Not meant to have fun with
The guys I know that have it put a switch in the line to turn it off and on.
oldsmobile joe
2,067
3,053
mpls
but the painless kit has the vacuum switch included to unlock the torque converter at part throttle. just like the pre-ecm factory design. i've used this style and was quite happy with it.
are people not using the vacuum switch?
