ECU - Is It Stock or Chipped
ed1948
1,286
1,613
Quinte West, Ontario
Here is a pic of my SS's ECU. Is this a stock or 'Performance' chip?
The reason for asking is I'm hearing pre-ignition(pinging) under WOT, timing at 6* BTDC, mid grade gas
ed1948
1,286
1,613
I have not done a timing advance test. I have a basic timing light and only the factory timing tab. I assume a performance chip would usually have an ID sticker on the chip.
Other causes of ping:
The THERMAC flap functions correctly. I have not verified the HEAT RISER valve functions correctly but it is free. I have not de carboned the combustion chambers - don't know if it's needed - plugs were clean. I tried different fuels. It's not a big deal now considering the driving season is wrapping up.
MrSony
6,793
6,679
Des Moines, Iowa
Plugs will tell you almost anything you need to know. Post some pics of all 8, in order (top row 1357, bottom 2468, etc) and we'll go from there. Be sure to take it on a nice long run too, maybe a few miles on the highway.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
ed1948
1,286
1,613
Re: P/N - The pic is from this spring when the car was being re&re'd. Never tried gas higher than 91 oct. rating. I hate to remove the ECU because somebody before me had monkey'd around with the kick panel and it did not line up well at reassembly. I checked the spark plugs last winter and they all looked fairly new and clean.
Maybe this winter I'll install the timing tape on the vibration damper - (the tape I bought 25 years ago but never used).
motorheadmike
8,976
27,522
Ummm... I still have all of that cruise control and ECM stuff sitting here in a box. PM me.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I know very little about the ECM, were they programmed differently depending on which car they were installed in?.
