Hi, sorry for asking a question that I have seen discussed before, but why shouldn't I use this kit (link to holley EFI below) and use my factory fuel line up to the engine bay for my 5.3l swap into '84 Monte Carlo and be done? Is there issues with pressure drop or fuel starvation if I don't use corvette pressure regulator up in the engine bay (link to filter/regulator below)? Is it easy to modify the hard vent line so that I can use it as a fuel return? I hear there is an orifice hole in the vent line so that it will only allow vapor out. My tank seems really clean, so I'm gonna keep it. Looking for balance between easy (holley in-tank return) and best practice. Again, sorry for posting a repeat theme here.
Holley Sniper EFI 12-306 Holley EFI Fuel Tank Modules - 255 LPH - GM G-Body Vehicles
This in-tank fuel pump module is a high-pressure unit that flows 255 liters per hour (LPH) and is capable of supporting electronic fuel injection (EFI) engines producing up to 550 horsepower. Featuring a pre-calibrated fuel-level sending unit designed to work with the factory fuel gauge for this...
www.holley.com
LS Fuel Filter Regulator
Tanks, Inc. manufactures fuel system components and polyethylene, steel and stainless steel gas tanks for street rods and special interest vehicles.
www.tanksinc.com
