El Camino
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I do a bit of reading and in doing research about frames I read that the A body El Caminio came with a boxed frame due to no roof to stiffen the car. I knew that one model of the Chevelle coupe and all the convertibles came with a factory boxed frame but I didn't realize the El Camino's did as well. I thought you guys with a El Camino that has a C section of the that is close to 10" longer than in the sedan G body would be interested in this.
Csilvy2000
251
87
Texarkana, AR
I've got a '78 model. Would that fall under the A body classification? I'm ignorant when it comes to the differences in the frames between the '78 El Camino and my '79 Olds Cutlass. Haven't even taken the time to visually look.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
It does fall under the A body classification but it meets the specs of the G body clarification so if you are asking if your frame is boxed from factory unfortunately it isn't. The wheelbase of your Cutlass is 108" while the El Camino is 117.1"
Csilvy2000
251
87
Texarkana, AR
So being a little longer framed, it's actually probably a little more flimsy. Interesting. And I guess boxing in the frames has been done on numerous occasions.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
if you take a g body frame in good shape on it's own you can lift one rear frame rail about a foot before it affects the other frame rail. Once I boxed my GP frame there is no more movement in the frame if you lift one frame rail and it stiffens up the car noticeably. I took the body off to do the body bushings so it made sense to me to box the frame at that time...
81Regal
1,558
485
83
Terril Iowa
My 70 El Camino doesn't have a boxed frame, neither did the 72 parts Elky. I believe it was just the convertibles and hi po A bodies.
