While browsing around on eBay, I found an electrically actuated cooling fan clutch off of an Envoy or Trailblazer.
It looks like it would be a direct replacement for a serpentine drive fan clutch, and give you the more accurate temperature control of a fan controller and the ability to switch the fan on with the A/C.
The wiring looks pretty simple as well. Ignore the hall sensor stuff, as it is just feedback for the ECM. All you need is +12v on the Wht/Blk wire and Ground to the Black wire.
Obviously not for everyone, but could be neat if you have a use for it.
