Im running a Lincoln Mark VIII electric fan from a relay to the fuse box and the fuse in the fuse box keeps blowing ANY HELP?THANKS
Upgrade the fuse like others mentioned, if that don’t fix, then see if the connections aren’t shorting out.yeah im running a 30 amp fuse
Don't just throw in a bigger fuse. Yoi could melt the wires and cause a fire.Okay ill try bigger fuse if that doesn't do it I'll try another mark VIII electric fan Thanks
