electric fan thermostat switch question
buzz77
304
60
Does this switch replace the stock temp sending unit thats mounted in the head? If so, what happens do the coolant temp gauge in the car? Thanks
buzz77
304
60
Then where does the thermostat switch get mounted? I've never paid attention to an electric fan wiring set up
buzz77
304
60
It is a stock intake 301. I'll eventually swap it or for either a pontiac 350 or 400. Whether that will have a stock intake or an aluminum aftermarket one remains to be seen. Right now I'm looking to replace the old stock radiator with an aluminum one, contemplating to go work an electric dual fan system.
darbysan
287
10
Las Vegas, NV
Not sure about your engine, but on a SBC, there is a port (Plug) in the passenger head, toward the rear, between #6 and #8 spark plugs.
Oct 14, 2008
8,818
7,763
Melville,Saskatchewan
There should be an extra port, the newer the motor, the more ports it has. Depends on if you are using the EFE valve. Even stock Olds manifolds have multiple ports.
buzz77
304
60
Talk about a eureka moment. Yup, there is a port right by the thermostat housing. Thanks guys. Would one switch support both fans?
Oct 14, 2008
8,818
7,763
Yes.
  • Useful
