WELL I BOUGHT THIS 1987 CUTLASS 442 THA WAS STORED FOR A LONG TIME. WHEN I PUT A NEW BATTERY IN IT I HEARD A SCREECHING NOISE FROM PASSENGER SIDE ND FIGURED IT WAS THE BLOWER MOTOR ALTHOUGH THE CLIMATE CONTROL SWITCH WAS OFF. SO THE BLOWER MOTOR RUNS ANYTIME THE IGNITION IS TURNED. SO I TOOK THE RADIO AND CLIAMTE CONTROL OUT TO INVESTIGATE AND FOUND THAT SOMEBODY HAS CONNECTED A WIRE FROM THE FUSE PANEL AND TAPPED INTO THE BROWN/WHITE STRIPE WIRE OF THE FAN CONTROL SWITCH SO THA THE FAN WILL RUN WITHT HE IGNTION EVEN IF THE HEATER IS OFF. IM GUESSING THE FAN DIDNT WORK OR WASNT GETTING POWER SO THEY JUST TAPPED A 12V SOURCE AND PUT IT TO THE FAN WIRE. ANYBODY KNOW WHY THIS COULD HAVE HAPPEND? I KNO THE FAN WORKS BECAUSE I UNPLUGGED THE WIRE THEY HAD ONNECTED TO A FUSE AND THE FAN DOESNT WORK. IT SEEMS LIKE THE BROWN/WHITE STRIPED WIRE IS NOT GETTING POWER AND SEEMS TO BE LIKE A REMOTE TURN ON WIRE FOR THE FAN. ANY HELP PLEASE ?
