I had my 1984 Hurst Olds attempted to be stolen awhile back and although repairs have been made I am still having residual problems. The car's steering column was smashed in an attempt to hot wire the car but the alarm system that cuts the volts from 12 to 6 stopped that. The thieves abandoned the car without any further damage.
The column has been replaced and the everything looked fine. After a fine weeks, a smell of wire insulation burning was noticeable and then a wisp of white smoke came from the lock cylinder in the steering column that was replaced.
The smell and smoke went away but now the car seems to running too rich as sparks plugs are continuing to foul out after only a few miles and the engine sputters at take off and low speeds. The electric choke was the first placed I looked and, except for the choke appearing to been stuck in the open position, all seemed fine. I even unplugged the wire from the electric choke. The fuses were check and everything was good there. The ignition coil was then replaced. All of this didn't seem to help.
I believe a wire has been pinch or scraped somewhere when the replacement column when it was put in. Before I pull the column to check this theory, I wanted to know if this was a good idea and ,if it is, what should I be looking for as far as replacing a part or which wire (knowing the wire color would help?) I would need to search for that would cause this to happen.
Any ideas or suggestions would really help and be appreciated.
Thank you.
Thank you.
