Hello all!
1978 Monte Carlo Landau w/ newer 350
I have what seems to be a ground issue, but I'm having a bit of difficulty finding it. When I turn my headlights on they will change in brightness as I drive (accelerate, brake, and other common driving mechanics...it's not that predictable). It's not only my headlights though, my dash lights and stereo will do the same. The stereo will come on and off. Problem is not as severe when the headlights aren't on.
I believe (and what reading I've done seems to support my belief) that this is a ground issue. I've checked the cables at the battery and replaced the terminal connection for the negative as well as hooked up an additional ground wire from the battery to the alternator.
Where else should I check? Are there any common problem spots? Could this be something else?
Thanks for your help.
