Eliminate Return Fuel Line
B
Buick 430 Olds
7
My 1983 Cutlass was a V6. It`s now a 430 Cu In Buick, 1967. I plugged the return fuel line at the tank and on the fuel pump. Now the fuel pump has quit working and I`m considering going to an electric pump. I`ve only driven the car 50 miles and it seems ok with the return line blocked but wonder if that led to the pump failure. Also not sure what kind of gas cap to use: vented, non vented, pressure, etc? Any input appreciated.
Bonnewagon
Bonnewagon
6,988
Queens, NY
The return line is there to recirculate fuel back to the tank. That way you always have fresh cool fuel at the pump. This helps prevent vapor lock. With a big motor like that I would definitely want a return line in place. Get a new three port pump, use the return line, the charcoal canister, with a stock non-vented gas cap. The pumps are about $20 at Rock Auto.
B
Buick 430 Olds
7
Thanks for the input on the return line. I`ll install one.
Reactions: fleming442
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,009
Socialist NY
Your pump failed simply because you didn't use the return
Look for a mechanical pump with 2 outputs instead of 3
Bonnewagon
Bonnewagon
6,988
Queens, NY
When you cap off the return line fitting the extra fuel has to go somewhere. It usually goes to the carburetor and causes an annoying minor flooding condition only at idle. In normal driving you won't notice but the plugs will start to foul. The cheap-*ss solution is to place a "T" fitting in the fuel supply line and route the return line into that. Then the excess fuel goes right back to the pump. Using a two fitting fuel pump solves this too but then your gas tank is venting out- where? Right, nowhere. So in hot weather you get pressure in the gas tank that may flood the carb. You may even suffer a collapsed gas tank when the pump removes gas and no atmosphere can replace it. Then you may be tempted to uncap the return line and that will serve as the vent. If it is at the firewall you will have gas fumes exiting under your hood. Best to just use the three fitting pump as the factory intended.
Thread starter Similar threads Forum Replies Date
J Throttle return springs? Oldsmobile Cutlass / 442 / Hurst/Olds 28
D return fuel via vent line Fuel / Air / Boost / Emissions 14
Chuck Cole Gas return line General Discussion 5
78_Monte970 Gas tank too big? Fuel / Air / Boost / Emissions 5
S Anyone used Fuel Injector Connection? General Discussion 2
dickeymoore Fuel gauge reading ????'s Fuel / Air / Boost / Emissions 17
Boli Fuel system G-Body LS Swap 9
UC645 Where would you mount a fuel pump? General Discussion 17
Emhendo Changed My Fuel Tank and All of a Sudden... General Discussion 27
P 442 307 fuel hose frame-pump tips?? Fuel / Air / Boost / Emissions 1
carnutjw SBC mechanical fuel pumps Fuel / Air / Boost / Emissions 3
J Monte Carlo Fuel pump and system everyone is using??? G-Body LS Swap 0
R HELP 07 silverado fuel pump power issues Non-G Projects 16
Mr.Monte81 Fuel Tank General Discussion 7
565bbchevy Well at least it won't starve for fuel when he stops. General Discussion 13
kygaca Fuel Pump: 2 Line VS 3 Line. Engine / Swaps / Driveability 9
MalibuDavyou5 Fuel Pump Fuel / Air / Boost / Emissions 8
Y MONTE CARLO High Fuel Pressure G-Body LS Swap 20
A fuel cell installation Fuel / Air / Boost / Emissions 8
dickeymoore Aftermarket fuel pumps ????'s Fuel / Air / Boost / Emissions 4
Chevytruc1658 Fuel Vent Line Question Fuel / Air / Boost / Emissions 2
g3chevy Holley Fuel Pump For Fuel Injection Fuel / Air / Boost / Emissions 4
64nailhead Fuel tank differences/interchange General Discussion 31
A El Camino gas tank retro-fit with Roadmaster Wagon fuel tank Chevrolet El Camino / GMC Caballero 10
O Rerouting fuel lines from sender Fuel / Air / Boost / Emissions 23
MonicaTheMonte Fuel Line Removal Fuel / Air / Boost / Emissions 2
MrSony Iowa- 350 Olds Fuel Injection Intake and 455? General Discussion 5
81MalibuMan Hard time finding fuel filter New Users 19
M Fuel Tank Vent Update 11/22 Fuel / Air / Boost / Emissions 44
D fuel tank replacement on my 81 malibu Fuel / Air / Boost / Emissions 9
jjmacswt FITech Fuel Injection Hesitation Engine / Swaps / Driveability 36
S V8 Fuel Pump Options Fuel / Air / Boost / Emissions 14
pontiacgp Fuel Pick Up Sock General Discussion 12
Bonnewagon NOS fuel pump? Reliable? Fuel / Air / Boost / Emissions 4
565bbchevy Fuel tank venting General Discussion 11
B Fuel system G-Body LS Swap 19
blackbuck350 Fuel cell questions Fuel / Air / Boost / Emissions 2
T fuel door upgrade How-To's / Knowledge Base 2
bertscova Spectra premium fuel tank ?? Fuel / Air / Boost / Emissions 1
bertscova Looking for fuel pump idea's Fuel / Air / Boost / Emissions 5
JAMCAR223 Electric fuel pump mounting ideas?? General Discussion 10
pagrunt Getting OCD with fuel line, go AN? Fuel / Air / Boost / Emissions 54
azmusclecar How important is the vent tube going from the carbon canister back to the fuel tank? Fuel / Air / Boost / Emissions 9
Epj1989 Fuel sending unit for 78 Cutlass Cruiser Wagon (cannot find!) Fuel / Air / Boost / Emissions 8
Similar threads
