Emissions Canister Rebuild
abbey castro
1,046
1,313
Harker Hts TX
I cut open my vapor canister using a hacksaw around the bottom lid ensuring I cut enough to just break the plastic weld. Bought a new lower filter and cut foam
for
the two internal
one with aquarium
m charcoal.
JAMCAR223
1,853
5,507
Houston, TX.
Nice job.
abbey castro
1,046
1,313
Harker Hts TX
The thing is that the hacksaw blade gives a clean cut vs using a Dremel disk that melts the plastic. I used 3m black rubber cement to reseal the bottom back to the cannister.
57 Handyman
339
389
AC, nice job and thanks for sharing your experience and success. I was planning to redo mine and after seeing your pictures will be careful not to cut deeply.
(y)(y)
69hurstolds
8,185
17,568
Yes, Fish tank charcoal. I didn't have my phone wit me when I filled it.
Bonus. I was going to say, that'd be one helluva vacuum leak without it. Good job on using a blade vs. the dremel. Those things were meant to be replaced, and not repaired. You would think they'd be as cheesy as some of the other crap and have a couple of snap clips on them or something. I guess they figured they'd outlast the car.
abbey castro
1,046
1,313
Harker Hts TX
Easy to do the rebuild. Go for it. My cannister had all the charcoal in it (filled 100%) and the foam filters were in good condition for being 35yrs old. I was expecting the foam to be disintegrating. I cut out new foam using the old ones as templates. The outside filter is readily available at your local corner auto parts for less than $2.75 bucks.
