Standard bolt size works fine.
10 pcs of M10 x 1.50 x 80mm & 2 pcs of M10 x 1.5 x 55mm are the normal bolts used.
Have fun with the cage nuts and 1/2" bolts!
As if they are not enough trouble with the proper bolts...add some more hassle at your own discretion.
It sounds like both to me. So far.Are we talking about suspension or body mount bushings here?
I was just being a smart-a$$. I think the OP was asking about rear suspension bushings.he is just mentioning the rear suspension bushings and that they use larger bolts so it sounds like control arm bushings to me
