Hello all,
I have a 1981 El Camino (231 V6) that has recently thrown an engine code. This is my first issue in the 18 months I've owned it.
I hadn't made any modifications to the engine, nor had I driven it hard. I can't explain the behaviour.
While driving around a few miles from my house the check engine light would blink five times, pause, another five times, and then a long pause. I brought it home and used the paperclip trick to display the code. I have a 5 pin port so I jumped the D and E pins (the one with the notch) and turned the ignition to accessory mode.
What happened next was a bunch of nonsensical blinking I couldn't nail down. I was already filming because I wanted to catch everything that was going to come up on the check engine light.
Does anyone have an idea on whats going on?
I think its probably looking weird because I have LED bulbs in there instead of the traditional bulbs so the resistance isn't what the ECM is tuned to for code reporting. I haven't swapped back because I haven't had the time.
Anyone else have any other ideas?
