Engine doesn't want to restart after having been driven
rogus
312
85
have a sbc 355 with a slayer 600cfm carb. this thing starts fine in the morning but doesn't like to re-start after it's been driven for awhile. Starter will turn the motor over and will eventually start but have to crank it over 2 or 3 times before it'll fire up. Seems only to have started behaving this way since the weather got colder. Any ideas on how to solve this would be appreciated.
Bonnewagon
Lost in the Labyrinth
10,563
14,293
Queens, NY
Vapor lock can occur even in cold weather. How is your gas line to the carb routed? Also if you have an HEI did you put the heat sink grease under the module?
rogus
312
85
pump to filter to an fitting to carb using high pressure fuel line as far as routing. I do use an hei. this is the first I've heard heat sink grease. can you fill me in?
lilbowtie
3,460
3,965
Canton Mi
Dielectric Grease - google it for Hei module. Check down the carb throat when you turn the car off to see if fuel is still dribbling in (flooding) bad float adjustment, bad float, bad needle/seat
rogus
312
85
will do!
