In my 355 SBC I have a BBC oil pump with is supposed to give about 15% more volume. I have a 7 quart pan to accommodate that pump. I seem to have excessive oil in the valve covers which doesn't seem to be a common problem with a BB pump in a SBC. I am in the process of putting fresh vortec head on the engine and took a look at the valves on the head I removed today. The valve seals are only as few years old and I'm pretty sure I used the proper seals but I was surprised that one valve fell out when I picked up the head with the valve springs removed. The valves always get cause by the seal with the keyway in the valve stem. the guides don't seem to be bad. I could see maybe one guide bad but not all of them so I'm thinking there may be too much oil in the valve covers. The exhaust valve has oil residue on the valve so they are dropping oil as well.
I'm not opposed to go back to the stock pan and stock pump. A stock pan will help to change the oil as well cause with the 7 quart pan I have to remove the slave cylinder for my clutch to remove the the oil filter. Here is what the intake valves look like.
