Engine year
1320John$$$
951
2,043
Pennsylvania
Date code cast in the block bell Housing just above block casting numbers inline with the distributor tower
pagrunt
9,155
15,321
Elderton, Pa
Beside the cast date on the back alot of times the VIN stamp pad with the engine code stamped that are one year only in most cases. Be aware the cast date could say 1980 for example & have a 1981 engine code but all would be correct.
DRIVEN
8,074
14,533
*CENSORED*
I like to use the suffix codes stamped on the deck surface, just forward of the passenger side head.
Using the link above, go about 2/3 down the page and click on the suffix group yours falls into. Using your letters, you can find exactly where your engine was born.
